Main Bearings Refurb!
Having recently purchased a 290 2002 after a ten year break from the sport, after a fantastic day out practising a disturbing rattle appeared. My colleagues, all fellow sherco owners grimaced and explained the dreaded main end bearing syndrome!!!!
How difficult is it to do yourself and where can I purchase a flywheel puller!!!
:D
  • Replies 33
  • Views 10.8k
It's as complicated a job that there is on a motorcycle.
That's not to say it's brain surgery or anything, but you'll be sorry if your transmission drops out and you have to chase it around the kitchen floor.
Check the RYP website for overhaul info.
If you're not sure about doing it yourself, you can save a lot of money by doing as much as you can, i.e. removing and stripping the motor as far as you can and giving what's left to somebody to do the mains.
My God!! I myself have been out of the game for years and bought a Sherco with main bearing rattle!!
Anyways in fairness I was told (and I could hear it) about my bikes problems before I bought it, back to the job in hand.
The job is straight forward enough, as you say you will need a flywheel puller and also a Clutch holding tool, there are other ways of locking the engine up to undo nuts but most of them can be a bit heath robinson.
Download all the files off the Sherco website and your away, besides the bearings and seals you'll also need: waterpump seal, base gasket, head gaskets (o rings) and a crankcase gasket (I thinkj thats the lot!).
I managed to do mine in a day (from start to finish), Don't buy the seals and bearings off the dealer...you WILL be ripped off.....I got the bearing numbers and seal part numbers off the Sherco website and I got them from a local bearing stockist for about 7 pounds in total.
have fun
Mark
Edited by Marky G
All of the required tools are availble from RYP (www.rypusa.com) I would assume that they are available from your local dealer.
Wayne
charliechitlins
And I thought I was the only one who worked on there bikes in the kitchen! I
I should probably let it pass, but as you are reading this, I will not.
While you could run around your dealer and get some of the parts from a bearing house or such, remember that when you are trying to get an explanation of how to do it. Or when your Dealer is no longer there to support you.
I have done it myself, and will do it again in the future I am sure.
But a good dealer is well worth the extra couple of pounds or bucks or whatever so that you get one stop shopping and the expert advice and experience that goes with it.
The soap box is getting slippery so I will get off it now.
Alan, I've got no problems buying from dealers if the charged ' a couple of pounds extra' but thats the point, on some parts folks get well and truly shafted......I wonder how much Sherco would charge for 2 main bearings and Crankshaft seals??
If only I was rich enough not to bother :D:P:(
Is there some kind of manufacturing problem with these sherco's then?
I've heard that some are noisy on the gearbox from new and some aren't, doesn't seem very good engineering to me, and also if you have to change the main bearings on fairly newish bikes seems a bit odd, no-one else think this too?
I got two main bearings and two DL crankshaft seals for a grand total of
Your right TX270, there must be something wrong, when you think about it...... we pay
Edited by Marky G
I guess you are getting a great deal if you are getting 2 bearings and seals for $13.
I am certain that they are the same quality. How does that work :huh:
Sounds good to me.
I am seeing a lot of China bearings at our local industrial supply house. Best check the quality, and the tolerance fits.
While I hate to spend too much for parts, I am also aware of the value of supporting the local dealer.
