April 15, 20233 yr Hey folks. I have a model 84 lobito 175 that I'm rebuilding. The engine was seized from water intrusion and the crank and rod are in terrible shape. The rod will barely even move on the crank. Do any of you know if there is an interchangeable crank and rod that I can use? Thanks
April 16, 20233 yr Hi ,, don’t know everything ,, I have few Bultaco’s ,, so my 2 cents , a pursang 125 I have had a small crankshaft it has 6 bolt head 1970 ish , have rare Sherpa 80 100 cc sure it has small crank has 4 bolt head like , Lobito some models , , think you would need to pull out crank and compare to average 250 , say pursang , or early Alpina Say relative 1970 ish , Check rod Bering size measure Bering surfaces , or go to a professional repair shop with crankshaft ,, O just for idea ,,,,,find a runner engine ,,,, p.s. I suspect the top end was off , exposed weather , can be a real mess ,, I purchased a engine in past , sat exposed cold , the trans gears were , a little rusty to , cheers 2 Edited April 17, 20233 yr by larry s. k. Word add 2
April 16, 20233 yr On 4/15/2023 at 12:00 PM, Loyal1975 said: Hey folks. I have a model 84 lobito 175 that I'm rebuilding. The engine was seized from water intrusion and the crank and rod are in terrible shape. The rod will barely even move on the crank. Do any of you know if there is an interchangeable crank and rod that I can use? Thanks Even heavily corroded crankshaft halves can usually be returned to serviceable condition by an engine re-conditioner and rod kits are readily available
