Femsatronic ignition question
70sBulRacer
Hi all, my Lobito 175 Mk4 basket case project came with a blue Femsatronic ignition coil that goes on the bracket under the tank.  I’ve only seen the reddish colored versions of this coil, which are shaped identically to the blue one I have.  The connections look identical as well.  Does anyone know if there’s a difference between the blue and red coils, or is one just a later version of the same part?
The easiest way to differentiate coils is to identify the number stamped on the coil bracket.  They will say ELB1-xxx or ELA2-xx   The femsatronic coils sometimes can be interchanged and work with lower units.  I actually have a list of what coil will match with what generator.  Having said that I would recommend using the correct matching setup.  There’s nothing wrong with femsatronic if it’s working correctly.  I’d continue to use it.  In fact the more it’s used the better it is for it.
steve
