rapid roy Posted March 14, 2006 Share Posted March 14, 2006 ANYONE KNOW WERE TO PURCHASE THE ECU CABLE AND PROGRAM TO RE-MAP THE 4RT Quote Link to comment Share on other sites More sharing options...
boydw Posted March 14, 2006 Share Posted March 14, 2006 you need to contact sandifords on 01282428383, they are not open on Tuesdays. You will require a throttle body if your bike is standard, plus a 12V battery to power the unit responsible for remapping the fuel injection. hope this helps Quote Link to comment Share on other sites More sharing options...
munch Posted March 14, 2006 Share Posted March 14, 2006 running leaner at small throttle openings off the bottom is unlikely to burn your valves Quote Link to comment Share on other sites More sharing options...
rapid roy Posted March 14, 2006 Author Share Posted March 14, 2006 I WONDER CAN THE MAPPING SETTINGS BE SHARED VIA E-MAIL ETC. OR IS IT JUST TRIAL AND ERROR Quote Link to comment Share on other sites More sharing options...
munch Posted March 14, 2006 Share Posted March 14, 2006 the software comes with 5 pre installed maps 1 of which is the base map Quote Link to comment Share on other sites More sharing options...
