thall1 Posted December 29, 2024 Share Posted December 29, 2024 Recently my bike overheated due to the fan not working.. fitted a new regulator and all was good. bike hasn’t been used due to gearbox strip down but now all rebuilt. bike ran at home with no issues in either the engine/ gearbox or the fan. Took it out Saturday and had intermittent fan for a few minutes then I lost all 12v on the bike again?… the bike starts and runs fine with fuel solenoid on the manual position .. fan will spin with a separate 12v battery connected. The regulator has five wires on the plug… black (earth).. two yellow from the stator and two blue which I assume is 12 volts output. what should I be seeing on the input to the regulator i.e on the two yellow wires? Quote Link to comment Share on other sites More sharing options...
thall1 Posted December 29, 2024 Author Share Posted December 29, 2024 Update… found the issue…. A Pin on a waterproof plug had snapped internally… it was being held in place by the grommet in the back of the plug which made it seem it was in place but in reality it was being pushed out when the connection was made 1 Quote Link to comment Share on other sites More sharing options...
stu109 Posted January 10, 2025 Share Posted January 10, 2025 Hi I had similar fan issues and thought I had solved the problem a number of times. In the end turned out to be a problem with the fule solenoid. If the issue returns try disconnecting the solenoid. Quote Link to comment Share on other sites More sharing options...
thall1 Posted January 12, 2025 Author Share Posted January 12, 2025 thanks.. i had that issue when i first bought the bike...i ran it with a fuel tap for 5/6 yrs before getting a new soleniod Quote Link to comment Share on other sites More sharing options...
