rock hopper Posted January 27, 2025 Report Share Posted January 27, 2025 Can I use synthetic Type ATF F oil on a 2003 200 txt. Read some ware not to use synthetic on these. Quote Link to comment Share on other sites More sharing options...
lemur Posted January 27, 2025 Report Share Posted January 27, 2025 The thing you don't want is friction modifiers, only use oil or if you must ATF that is designed to work on wet clutch applications suited to the plates you are running be that cork, paper or carbon fibre. The transmission is non filtered so the best oil is the one you are likely to change most often. Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted January 27, 2025 Report Share Posted January 27, 2025 3 hours ago, rock hopper said: Can I use synthetic Type ATF F oil on a 2003 200 txt. Read some ware not to use synthetic on these. DEXRON III if you are using ATF , its tried and tested for decades in competition Trials bikes. 1 Quote Link to comment Share on other sites More sharing options...
