June 3, 20251 yr I have a set of OZO shocks on my SWM TL320. They aren’t leaking oil but are very springy/bouncy. They have shrader valves can i fill them with air? If so how much? I know you’re supposed to fill with nitrogen but I have a trials this weekend and no way to get that done right now. But the air would be temporary. Thanks
June 3, 20251 yr Dry air would be OK as a temporary measure, but moisture in the air will eventually cause corrosion. This thread mentions pressure: https://www.trialscentral.com/forums/topic/69619-ozo-pro-trials-rear-shocks-a-look-inside/page/2/ Edit: A more complete answer is that it's the combination of oxygen and moisture in the air that will do the damage. I think using a bicycle tire pump would be much better than a shop air compressor that has not been drained immediately beforehand. Edited June 4, 20251 yr by konrad
