bobb Posted June 22 Report Share Posted June 22 Hello, Are there companies making a racing wire loom? I know future used to make a very minimalistic wire loom for 4rt's but they are no longer doing that ? What can be taken off the bike ? i have seen some monts where a lot of those rubber tubes and catch tank and other stuff have been taken off so you get some space to work on the engine . I have seen smaller HT coils and smaller condensors beeing used to Quote Link to comment Share on other sites More sharing options...
mcman56 Posted June 23 Report Share Posted June 23 With the Jitsie electric start kit, the bank angle sensor assembly is removed. I'm not sure that is a good idea but assume it was done to make space for other components. I have seen no formal description of what the sensor assembly does but it likely cuts power to the fuel pump when the bike is on its side. I guess is could cut power to the whole FI system. Quote Link to comment Share on other sites More sharing options...
bobb Posted June 24 Author Report Share Posted June 24 that bank sensor is already gone on my bike you do need modification to the wire loom for that This is alex ferrer's bike anyone knows where they put the ignition coil? I think this looks a lot neater that the stock bike who is full with tubes and wires everywhere and a pain to work on. Quote Link to comment Share on other sites More sharing options...
marky boy Posted July 1 Report Share Posted July 1 Ignition coil will be under the seat next to the throttle body , that is where mine is. Quote Link to comment Share on other sites More sharing options...
