2001 280 txt
arden
2 hours ago, arden said:
HEY EVERYBODY
RUNNING 80-1 AND PLUG IS WET ALMOST LIKE ITS RICH. IS THIS NORMAL?
What octane fuel?
If in doubt drop the main jet needle one notch and test ride it 👍
Tell of too much oil in your pre mix is how badly the exhaust plugs up with unburnt oil residue, naturally fuel rich condition intake also relates to oil rich.  Your air cleaner filter needs to be clean and oiled correctly or that will starve the engine of air and lead to rich operation and poor performance, the reed valves need to seat perfect or scavenging pressure will force fuel and compression backwards through the intake so make sure the reeds seat perfect.  Compression test is never a bad idea for diagnosis and future reference if you have the equipment. 👍
