Crank removal
fiddler2
20 hours ago, fiddler2 said:
Need to do engine inspection .. advice for splitting crank case   . What needs to be removed ? Clutch ,crank weight . Mag off, oil seal carrier . Kick and gear off already   hot air gun help?
Don't normally need hot air gun for Bultaco unless someone has used sealant on the centre gasket.
gearbox output sprocket and seal spacer
cylinder
shift drum external mechanism
shift drum indexing plunger
all the nuts and screws - one screw is tricky to see
  • 3 weeks later...
