2016 Vertigo 300 capacitor
JBROWN
Hi can anyone advise how to test this capacitor from a 2016 Vertigo (it’s got the batteryless upgrade). I can use a multimeter and read micro farads etc, I just don’t know the valves I should see (there are 3 pins, nothing written on the unit). Also would this being faulty cause failure to start (definitely no spark) ?657CB8CE-9C09-428D-8F01-1A71045C88C8.thumb.jpeg.eb17d5953d0369b40addd257489b51ff.jpeg
Generally the capacitor is not a tremendously expensive or special part and worth stocking a spare to test or replace, the primary reason it is on there is because your bike is fuel injected and Fi needs DC power in the form of a battery and or capacitor to supply sufficient electrical power to the DC fuel pump.  Symptom of a failed cap on your ride would be lack of fuel pressure not lack of spark.
A capacitor is a 2-terminal device.  The third terminal is likely connected to one of the others to simplify the bike's wiring.
For reference, the OSSA's capacitor is approximately 22000 uF.  Most multimeters will not read a capacitor value that large.   10000 uF is a typical limit.
If you connect the capacitor to your multimeter on the ohms setting, the resistance will appear small initially, and gradually increase as the capacitor charges.  You can then short the capacitor leads together (discharging it) and repeat the observation.
The multimeter will charge the capacitor to something on the order of 350 millivolts.  Once the capacitor is charged, switch the multimeter to read volts (or better yet, millivolts).  The capacitor should hold that charge for a long time (perhaps hours) but you will be able it see it slowly discharge due to the drain imposed by the multimeter.
Passing these tests does not guarantee a good capacitor, but it's better than nothing and about all the DIY mechanic can do.
P.S. An electrolytic capacitor is a polarized device. Operating one at its rated voltage backwards will destroy it.  But when testing will a multimeter, polarity is not a concern.  This is because the voltage is so low, no damage will occur.
Edited by konrad
If there is no spark start by checking the stator windings and ignition pickup outputs, your spark plug does not use the capacitor to make a spark.
... interesting that one would consider a capacitor to be an upgrade to a battery 🤔 if I was building fuel injected motorcycles I would think a capacitor in place of a battery would be a cost and possibly weight saving measure, not a performance improvement.   Both are power storage devices but a battery maintains an electric charge for a considerable time where a capacitor retains a charge until it is discharged and then it becomes basically flat or dead.  The cap won't charge until you start cranking the kickstarter, a battery in theory would be ready to provide full power right from the first kick.
Hi and thanks for your reply, I didn’t upgrade to the capacitor- it was apparently a dealer/manufacturer ‘upgrade’ made worse by the fact no local dealers or Vertigo UK have a wiring diagram for a 2016/2017 bike !
I will start with the stator etc tonight. Thanks again
Edited by JBROWN
imho an upgrade would be to keep the small battery and add a capacitor and if it is only a cold start problem install a jumper port where you can easy plug in a small power supply.
I have tested the stator 0.6 ohms between 1-2, 1-3 and 2-3. No continuity to ground so that should be ok.the pick up is 101 ohms.
Edited by JBROWN
I use an oscilloscope to test the AC outputs, nothing beats that, your pickup coil should ohm meter test easy and be adjusted (if possible) for the closest proximity to the magnets to optimize performance, pickup is simply a field coil that initiates the spark and provides timing for the fuel injection.
