Nibbi carburettor
bikeskint
Anyone used the nibbi carb as a replacement..? The Amal MK2 2627 on my TR77 needs a complete rebuild including a New slide. I can buy the nibbi And a selection of jets cheaper 🤦‍♂️ do I replace or rebuild
I assume this is cheap pwk copy? I have fitted a koso to my m159 (325) Bultaco, after bit of jetting it runs well. When I fitted it it flooded and I had to bend  the float tang to cure. I only really  wanted to see if it would work as the standard Bing was stuffed. I know people  will say they are rubbish, but it is a cheap  way to test if a Keihin would work
