TY175 cylinder options
Niro12
25 minutes ago, feetupfun said:
DT175 1974,75,76,77 (DT175 ABCD models) cylinder will fit and function well but has different finning outline to TY175. I have not tried or measured up a CT1,2,3 cylinder.
Got it. In case I'm going to use DT175 cylinder -
- Do I need to use DT175 cylinder head?
- is it possible to make a new thread for the clutch cable holder?
- Do I need to trim the fins?
thanks.
thanks.
You can use the TY175 head or the DT175 head. If you use a DT175 head, the compression ratio will be higher but you may need to trim the head fins for exhaust pipe clearance.
You can mount a clutch cable holder on the engine casing or on the bottom cylinder fin.
The DT175 cylinder fins will not interfere with anything physically. Trim them if retaining the original TY appearance is important to you.
