cello Posted December 22 Report Share Posted December 22 Just airing this to see what you think , ran a Compression Test on my Techno 97 and got nigh on 170 PSI , whan I had the exhaust off I took a look at the piston and it looked worn and scored but this bike seems to have a lot of compression whn kicking it over and seems to pull very very well low down. Tried a 2014 Evo 250 and only go 110 PSI well it was more like 106 but I rounded up, is this right? I know it all depends on the life that the engine has had but I would have expected it to be the other way round with more compression from the Evo, the Evo does sound a little slappy like th little end is starting to knock so its goinf to have the head off for inspection at some point.. I must say the Evo controls all work perfectly compared to the Techno , brakes particulary but I guess if the Evo motor is good it should pull hard in all gears even the high rato 4 and 5 but its difficult to test round where I live as the bike is not road legal. Is there any road test I could do to test the motor out as I dont want to DNF because of the motor notfiring up or not pulling up a hill in a wet soggy trial New Years trial I'm thinkin of entering. TIA Quote Link to comment Share on other sites More sharing options...
konrad Posted Tuesday at 12:07 AM Report Share Posted Tuesday at 12:07 AM A lot of factors go into making an accurate compression test. A few things to think about: Compression must be tested with the throttle held wide open. I usually keep kicking until the gauge stop rising. This can often be a dozen kicks. The spark plug adapter you use can make a big difference if it increases the combustion chamber volume appreciably. For example, using a short-reach adapter in a long reach plug hole gives inaccurate (low) readings. If the piston crown and/or combustion chamber has a large about of carbon buildup, this will increase the reading. Smaller cylinders tend to have higher cranking pressure than larger ones. The barometric pressure (altitude) will affect the exact number. A hot motor will make more cranking pressure than a cold motor. Oily cylinders tend to make more pressure than dry ones due to a better ring seal. There are other factors too. 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted Tuesday at 10:58 PM Report Share Posted Tuesday at 10:58 PM One way to judge piston ring seal without pulling much apart is to inspect the cylinder wall via the exhaust port or the plug hole, looking for dark areas (carbon). Carbon on the walls indicates piston ring blowby. Be aware that trials two strokes nowadays commonly suffer from having the rings stuck in their grooves by gum and carbon. This can happen quite quickly depending on how the bike is ridden, the type of premix oil and how well the bike is jetted. Quote Link to comment Share on other sites More sharing options...
cello Posted Friday at 11:16 PM Author Report Share Posted Friday at 11:16 PM Thanks for the replies both, well having finally got out to ride the Evo I must say the power is there in abundance! Too much power actually as I flipped the bike at least twice may be three times today , this was more my ineptitude then the bikes fault ofcourse but the geometry of the bike and low gearing and my riding style which was always to muscle the bike around made a lethal combination lol I was thinking of taking the Techno out but I think that could be even more of a handful but I need to do a lot more practicing before entering a trials that for sure........I'll keep the Low compression for the moment , thanks again gents Quote Link to comment Share on other sites More sharing options...
feetupfun Posted yesterday at 01:25 AM Report Share Posted yesterday at 01:25 AM 2 hours ago, cello said: Thanks for the replies both, well having finally got out to ride the Evo I must say the power is there in abundance! Too much power actually as I flipped the bike at least twice may be three times today , this was more my ineptitude then the bikes fault ofcourse but the geometry of the bike and low gearing and my riding style which was always to muscle the bike around made a lethal combination lol I was thinking of taking the Techno out but I think that could be even more of a handful but I need to do a lot more practicing before entering a trials that for sure........I'll keep the Low compression for the moment , thanks again gents A standard 250 1997 Techno has a lovely soft motor. Technos came out in 1994 and were highly responsive - probably too responsive for the average rider. The 1996 model was made much easier to ride for the average rider and it stayed like this for the rest of the years of the Techno (96, 97, 98, 99). By the way, is your Techno a 250 or a 270? Quote Link to comment Share on other sites More sharing options...
cello Posted yesterday at 10:48 PM Author Report Share Posted yesterday at 10:48 PM Thats worth knowing. thanks Feetup! I must say the ancillaries especially the brakes are much better then the Techno's and they are vitally important much more then the power delivery , I found that out the hard way! I think its a 250 but have not had the head off to confirm, compression is way higher the the evo and you can feel it on the kick starter, she does start normally on the 2nd or 3rd kick after being left for a few weeks. I did measure the bore through the exhaust port when I got her and althouh a rough measurement think it came out at nearer a 250 then a 270 bore. Parts being hard to get now with the tail piece in particular looks almost brand new so not sure I will take her out much unless I can find another tail piece/rear mudguard at a resonable price such is my looping tendancy atm 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted 1 hour ago Report Share Posted 1 hour ago 22 hours ago, cello said: Thats worth knowing. thanks Feetup! I must say the ancillaries especially the brakes are much better then the Techno's and they are vitally important much more then the power delivery , I found that out the hard way! I think its a 250 but have not had the head off to confirm, compression is way higher the the evo and you can feel it on the kick starter, she does start normally on the 2nd or 3rd kick after being left for a few weeks. I did measure the bore through the exhaust port when I got her and althouh a rough measurement think it came out at nearer a 250 then a 270 bore. Parts being hard to get now with the tail piece in particular looks almost brand new so not sure I will take her out much unless I can find another tail piece/rear mudguard at a resonable price such is my looping tendancy atm Yes 4 pot front brakes were a huge advance in brake control compared to 2 pot. The EVO also feels substantially lighter to ride than the Techno. I remember riding my first Rev 3 in about 2001 and being amazed at how light it felt to ride compared with a Techno. Quote Link to comment Share on other sites More sharing options...
