Niro Posted 3 hours ago Report Share Posted 3 hours ago Hi, The ball and the spring for the shift cam can be installed through the threaded hole when the cases are put together? or only when the cases are split? (the cases are currently split, and there actually no ball, just spring) Part number: 93505-16006 (#6 in the attached picture) thanks Quote Link to comment Share on other sites More sharing options...
