scoobie232 Posted April 19, 2006 Share Posted April 19, 2006 I have an 05 250 pro which has taken a knock at the master cylinder letting out some fluid and in some air, I see the system takes mineral oil instead of standard clutch fluid what type/brand/make of mineral oil should i use and where would i get some locally ?. Thanks.. H. Quote Link to comment Share on other sites More sharing options...
coxy Posted April 19, 2006 Share Posted April 19, 2006 you may be able to get some from your local bike shop as some of the bikes have hydraulic brakes which use mineral oil but dunoo if it is any good for a trials bike Quote Link to comment Share on other sites More sharing options...
coxy Posted April 19, 2006 Share Posted April 19, 2006 well i got told that if you use any other thing apart from mineral oil then it will corrode and damage any seals whixch it is in contact with for a long time Quote Link to comment Share on other sites More sharing options...
pandelboy Posted April 19, 2006 Share Posted April 19, 2006 hi the oil you want is LHM mineral oil as used by citroen as previously described Quote Link to comment Share on other sites More sharing options...
scoobie232 Posted April 19, 2006 Author Share Posted April 19, 2006 Got some LHM+ , "mineral based brake and suspension fluid" from my local auto shop today, system now fully bled with no drag. Thanks to all who replied. H.. Quote Link to comment Share on other sites More sharing options...
magicmat Posted April 25, 2006 Share Posted April 25, 2006 Err....hmmm My 05 280 clutch dragged, checked it, and no fluid in teh reservoir !! so i bled it from the bottom up, with valvoline 5.1 DOT brake and clutch fluid, i had no idea that they use mineral and synthetic stuff, i used the bike for two hours,...and now its sat there, for what will be 1-2months,..(at uni got exams).. if its syntheitc stuff, should i ring my dad and get him to change it ? or will it be alright and change it later... Fan BLOOMIN tastic !! Quote Link to comment Share on other sites More sharing options...
ham2 Posted April 25, 2006 Share Posted April 25, 2006 Get on the phone ( there's a reason the fluid drained off in the first place)and tell Pa he's got 2 oil jobs now-drain the clutch master/slave and the gearbox. Quote Link to comment Share on other sites More sharing options...
magicmat Posted April 25, 2006 Share Posted April 25, 2006 SERIOUS !! darg-nabit !! well its being stood it should be drained anyway, i didnt really think about where the old oil went just thought after a year i went...lol...that sounds stupid, but the fluid i took out had some serious crap in it, i mean actual DEBRIS !! HO hum, i suppose Quote Link to comment Share on other sites More sharing options...
magicmat Posted April 25, 2006 Share Posted April 25, 2006 (edited) Sh*t does this mean that all my rubber seals are dead ?? if it gets drained tonight it will have been in there... 48 hours....great... Can you use DOT in the brakes then ?? Edited April 25, 2006 by Magicmat Quote Link to comment Share on other sites More sharing options...
magicmat Posted April 25, 2006 Share Posted April 25, 2006 Called <mention of this company is not permitted on Trials Central>, Yeah, new seals and wash out with mineral, well...it needs refurbing anyway... The outerseal was getting tatty and had broken, and the fluid must have gone somewhere before ??? so this will sort this problem out. I had a maintainance day planned for after my exams anyway !! hehe. gonna flush it out with mineral, then leave it stood with mineral in, then in 2months, ill change the seals, GB oil, before i ride it. All good ? (will stop filling the threads with my posts now. Sorry) Mat Quote Link to comment Share on other sites More sharing options...
