July 7, 200620 yr After about 15-20 minutes of riding my bikes just stalls for no reason and takes about 5 mins to get going again! is thsi something serious or is it something simple? any help would be appreciated!
July 7, 200620 yr Check the petrol tap - to make sure fuel is coming from tank - you may have to remove the tap and cut some off the "standing pipe" which was a problem on some earlier models - an easy fix - check with Rathmells or look at the info on the RYP site.
July 7, 200620 yr Check the breather to the petrol tank cap is clear - you might get 15 minutes running before the vac in the tank stopped the petrol coming out
July 7, 200620 yr Check the inlet filter. Not everybody remembers it when they check the carb. If there's muck in there, it can get to a point where the flow of fuel is just slightly less than the speed it's using it, and do exactly that. Mine did it in the Manx 2 years ago (twice). Some dodgy fuel I think. In case you're in any doubt whiere I mean, it's the 10mm (I think) bolt where the fuel pipe enters the carb. Banjo connection seems like a good name for it, but only because I don't know what the real name is.
