Sign in to follow this
Followers 0
wrmec
Base Gasket
8 posts in this topic
hello. i need to change the base gasket on my 2006 300cc gas gas txt pro as it is leaking and blowing. i have got the gasket but i would appreciate any advice on doing this job before i start. thanks.
Share this post
Link to post
Make sure you drain the cooling system first. Get new o-rings for the head. You should be able to get the gasket off without removing the piston but if you do remove the piston it is a good idea to replace the wrist pin clips with new ones.
Check the sealing surfaces - particularly in the area where it was leaking to be sure there is no scratches or erosion that will cause a new gasket to leak in the same place.
Remember that there are different thicknesses of gasket and that they are used to adjust the squish height which affects compression ratios and power. Some people just use the thickest standard gasket to make the job easier. This would lower the compression which will reduce both pinging and power.
Don't drop anything down into the bottom end and be sure to use a torque wrench to tighten the head bolts. I like to use a good anti-sieze on the threads. Retorque the head after a few hours of running.
Share this post
Link to post
I drain the cooling system by removing the hoses from the water pump.
Yes, clean the black stuf from the inside of the head. Be careful not to gouge or scratch the metal. I use carb cleaner or lacquer thinner and a rag.
Share this post
Link to post
you don't need to take the head off, you can take the cylinder off with head still attached.
sounds like its too late for that.
I did this last weekend to my gas gas, left the head on, took barrel off complete, ,
cleaned up the piston, new thicker base gasket,(two actually)took about an hour.
Cured the pinking/pinging
TLTEL
Share this post
Link to post
I am back on this job after a few days away and I am struggling to take the cylinder off, it is just the four bolts isnt it? Anyone got any tips? Thank you
Share this post
Link to post
Squirt some oil down the plug hole, and turn the engine over do the piston is at the bottom of its stroke. After the four nuts are undone (and the ally brace is removed) it should lift / slide off fairly easily, a bit of moderate resistance at first then it'll pop off. A couple of gentle taps with a rubber mallet will help break the base gasket seal.
Edited by tankygsy
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
