2002 Pampera 280 - Fluid Questions:
johnmc408
The manual says 10W40 750cc.  The Internet says ;-) 650cc if just an oil change.  And I have seen 10W30 as well.
Other posts recommend ATF (F? or Dexron3?) as that seems common for GG trials.  It *looks* like ATF is in there now (red-ish)
I haven't heard of 10W40 for a trials bike, so I thought I would double check.
Right now the clutch is "grabby" in first gear when riding a figure 8 (so bad it is kinda hard to do at idle speed).  The bike probably had been sitting for 3-4 months.  Wondering what is updated wisdom on this before I change out the oil.
Also, the manual says this for gas/oil ratio:
A semi-sintehetic or synthetic oil for twostroke engines should be used for the oil-fuel mixture, with a ratio of 1,5.
Does this mean 50:1 or 80:1?  I have an older trials bike that is 80:1, would be great to use that.  Or maybe both at 70:1?  Not sure how sensitive these bike are to the ratio...
Thanks!
Edited by johnmc408
