svennl Report post Posted June 18, 2006 The oil filler cap on my SY250 is just a cap, not a dipstick. So how do I check the correct level of the transmission oil? The instruction manual pdf doesn't mention this. Anybody knows the trick? Share this post Link to post Share on other sites
boofont Report post Posted June 18, 2006 By far the easiest way to do this is to change your oil and measure the right amount to put in. If you really want to check it then there's a bolt on the right hand side just between the casing and your brake pedal. Undo it and if oil runs out it's ok, if not then you need to add oil till it runs out. You can find the procedure in the Scorpa SY manual here. Share this post Link to post Share on other sites
ned kelly Report post Posted June 18, 2006 (edited) Change the oil...... NOW! If you think you need to check it - change it! Yamaha say 700cc on side cover, Scorpa say 600cc in manual. 650cc of the best synthetic 2 stroke oil sounds good HUH! Edited June 18, 2006 by ned kelly Share this post Link to post Share on other sites
dgshannon Report post Posted June 18, 2006 If you think you need to check it - change it! I agree. You should change your oil, with enough frequency, that checking it doesn't come into play. I have always used 600cc in all 3 of mine. Share this post Link to post Share on other sites
angusmcbigpants Report post Posted June 20, 2006 why the need to check the level of your oil? unless you have a puddle on the garage floor. what you need to do is just change it as often as you can, every couple of outings is a good guide but thats up to you. you can change it every time,but not really any need. just remember to use agood quality oil i use pj1 75w light gear oil, it seems to suit my bike and i,ve had no problems with clutch drag since using it. glad you chose the sy you have made a great choice and i hope you enjoy .angus... Share this post Link to post Share on other sites
