May 27, 201016 yr Hi all, I'm going to look at a 2004 250 pro tomorrow evening. Is there anything in particular I should look out for on these bikes? Any known issues with them? Thanks, John
May 27, 201016 yr Wheel bearings Suspension bearings water pump leaking into oil (white oil in level viewer) exhaust rubbing on tyre cracks in air filter housing
May 28, 201016 yr Author Wheel bearingsSuspension bearings water pump leaking into oil (white oil in level viewer) exhaust rubbing on tyre cracks in air filter housing Thanks Blocky! Stabilizers?;-) Fcuck Off Graham!
May 31, 201016 yr Author Well the gearbox was full of water, but I couldn't resist and bought it anyway! Fingers crossed a new waterpump seal will sort it... What's the best way to flush all the milky cr&p out? Is it just of matter of changing the oil a few times, or is there a better way?
May 31, 201016 yr Buy the seal, the shaft and bearing. Its about 99% certain that the shaft will be worn and you'll just waste your money with the seal. Been there... done it Pop over if you need a star drive to undo the impellor, im only in Huntingdon Edited May 31, 201016 yr by Blocky
May 31, 201016 yr Author Buy the seal, the shaft and bearing. Its about 99% certain that the shaft will be worn and you'll just waste your money with the seal.Been there... done it Pop over if you need a star drive to undo the impellor, im only in Huntingdon I've just finished taking it apart and the shaft and bearing are indeed buggered! Thanks for the offer, I'll give you a shout if I get stuck
