I guy's , took my 250A out from the basement today, It started right up but it seem that it only want to run with the choke on, maybe the float is not well ajusted will check that tomorow.
First trial comp off the season sunday ( first in 30 some years ) I hope I will have the problem fixed.
What happend when you put a DT piston in a TY 250 A? Has anybody tried?
I Rhodewarrior, I have in the shed a CANADIAN original 493 ( 1976 ), I don't know how to post pictures but if you are able to give me your email I can send you quite a few picture that I took this fall since I want to sell the moto.
Ok guy's, here what is puzzling me : when you increase the rear wheel travel by instaling longer shock and/or moving the top anchor point does it change the balance of the machine, as I told before, I always tought that the front end of the TY was '' heavy ''.
Well guy's the more I read the more I'm puzzled, I have 2 434 frames and a b model in the shed all 3 of them with original shock ( 315 mm ), and same configuration. It seem that 340 mm shock is the thing to get, unfortunatly I have never been able to try a mod TY neither SEEN a modified TY much less a Majesty frame, here in Qu
I am reading Frank's questions and the reply, and I am very interested since I am preparing a 434 model for this spring: engine done (new rod kit, piston, ring, bearings and seals ) no autolube that Mikuni carb mention earlier, footrest repositions , the 360 DT piston job will be the next fall project.
Will the shock mount position on the D model that Frank is preparing be the same that on my A model that as never been modified?
I am new to this site and to had to the pleasure !!! I am a french Canadian, so please forgive me for amy wrong spelling or maybe using the wrong term. I was reading the post on putting a DT 360 piston in place of the 70 mm std, do you have to install a DT sleeve in place of the original one, and also I have heard that they use the same 26 mm carburator is it ok?
I am planning to replace the original carburator, I whant to install a VM Mikuni, am I going in the rite direction.
I have been out off the trial world for 3..some75aaebab35af9c8d3975e2dc20c91d8f
Genuine Ty250 T/s Pistons Anyone?
in Yamaha
Guy
