guy53
    615
Posts posted by guy53
  1. i just receved yesterday the entry form for this year Vintage Fest at Ormstown Qc , and for the 3rd year Mick will be there. I look foward to meet him again, as you all said great MAN. He does'nt only advise you on riding technic, he generously give you pointers on '' setuping '' your bike. If you never attend Mick trial scool, you miss something.
    Guy
  2. I use to ride a TY A with the flywhell lightened, now I ride a B model with the same flywheel. I could'nt bring myself to put the super heavy B model one. Might be the right thing in mud mud mud !!!
    As far as the MAR, I only tried one and it was not setup for me so I did'nt like it but the owner was cleaning it sections with 2 finger in the nose I would '' 5 ''.
    Jon, the extra ground clearence make a lot of difference.
    Guy
  3. If you plan to make the mod David did on the Peter Pace replica, think twice about the next trial you want to attend with that bike. I have acces to a machine shop and I worked in maintenance for a long time, I can tell you that it took me a lot more time than I thougt it would, and the final assembly is often not the final assembly as you have to custom fit everything. So I realy tip my hat to you David, planning and realising that bike with nothing but old photo to refer to, I don't know how you did it.
    I hope you enjoy riding that TY as much as I do.
    Guy
  4. I have a set ot Betor trial expert and a set of NJB ( both 340mm, 40 pound spring ) on standatd and modified TY and I like the NJB trial Expert, I should tell you that I'm an average rider, so maybe I cannot tell the difference.
    Guy
  5. Hi Thats_a_five, if you look at the other picture you will see Mono and IT piston, machining a new sleeve with the exact porting is a lot of work since I only found one second OS for std 250 mono.
    After the holiday decision time will come so ....
    Guy
  6. Fantnik : Thank's I will check Wiseco although I'm not there biggest fan and also give Mitaka a look
    Tony : Yes the piston pin is set close to 2 mm lower on the Mono ( probably because of the 68 mm stroke vs the IT YZ TY ts stroke is 64mm ) and the skirt of the piston is also longer on the Mono. So if someone have done the mod they had to mofify the cylinder base and the also machine the head .
    2stroke4stroke : Yes I'm looking for a barrel or a complete bike for parts, but here in Québec ( Canada ) they are few, and I looked all over the net to find a piston ring set.
    Hopefully I will find the parts or the correct modification to do because as you can understand I can't make mistake.
    Guy
  7. The bad news came this morning, I need a 3rd OS piston ( and ring ) for my 250 Mono. I didn't find one and I am told an IT ( or YZ ) or a TS piston would fit with modif made to the cylinder and head. Quite a few post are scratching the subject, but if someone as done the job with good result I would apreciate the details. Of course my first choise would be a 3rd os TY but ... I also will change the rod , but replacement is avalable. There are 2 different type of IT piston, the one with the '' arche '' is suppose to be beter but wear faster. I don't realy use the last bit of power of the bike since I am an average rider. So TS or IT and if IT, withc one choose?
    A couple of picure of IT VS std TY http://s1065.beta.ph...837536139540032
    I should say that TS piston is not a problem to get .
    Guy
  8. I'm not a specialist, but every time I can, I have a test ride on any trial bike, and my TY B and I have in mind a couple of A and D just work fine, not at par with a good SWM 350 but beter than any 250 that as not been cared for.
    Good clean well tune carb, CLEAN exhaust ( very important ) replace the head gasket by a thinner one ( .005 to .010 ) good piston and a sprocket combination that suit your riding style. Voila... a respectable TS. Yes you have to set up the suspension! As Andy wrote I took the flywhell weight off on my B but this winter I will put it back on ( maybe a little lighter than the one on 434 model ). But Dixie your not the first one with that impression, if you dig a bit you will find more than one thread asking your question and getiing more advise than I write in this reply.
    Guy
