guy53
    615
Posts posted by guy53
  1. I gess it as, but, with the footrest lowered, it as to compensate. Plus the change of the position of the top shock mount and there lenght also change the fork rake witch make it, in my opinion ( might not be the best ) easier to ride. I live in Québec, no other Ty that I know were modified to these specs, but I still have a standard TY and even if I am NOT an expert ( lot of weight on the NOT ) I can tell you as I commented in an other post : yes it's worth the trouble to make the mod.
    Guy
  2. A clean exhaust, good timming and a rebore with a genuine piston ( at least a 2 ring piston ) to factory spec. is ok, for a little more punch you can play with he flywheel weight. That what I did to 2 ( an A and a B model ) and it work ok for me.
    Guy
  3. When I reposition the shock on my B model, I already had a pair of NJB trial expert 340 mm on the bike. I also lift the motor one inch . I have to tell you that I am not an expert rider, but an experience one. First thing I notice is: the steering felt better, second: when I tune the shock properly , the bike feelt smoother.
    The front end angle as changed a bit due to the lifting of the rear, and the longer travel of the rear wheel made it smoother. I can't tell you it made a better rider out of me, but I can tell you it made a happier one.
    On the one I am riding now ( B model ) I positioned the shock mount 11 1/2 inch from the center of the swingarm pivot, and the one I am bulding now 11 1/4 inch. If my brother was to buy a TY, I would tell im to first: reposition the footrest and second reposition the shock mount, so ...
    Guy
  4. I took the flywheel off my TY 250 after a few rides on it , I was a little afraid that I would loose traction easily in muddy section, but with the tire and suspension that are avalable now, I never had any problem . I'm not a top rider and my throttle control is not the best, but I never considered replacing the no-weight flywheel with the spare one I bought just in case.
    Guy
  5. I had a TY Mono 250 ( with my 2 TS ) that I refresh with new 2nd o/s rings, when looking for those ring I found out rods rings and piston where very rare. So in my '' quest '' for ring I found a 3rd os piston and ring set at 220.00$ US.One and a half time the price of a genuine Yamaha TS piston I bought it. The original piston have close port as the one on the web site have open ones, according to Mick And.. they work very well but wear faster. If you want a picture of the original piston, pm me.
    Guy
  6. Hi Kee, I live in Québec where there is quite a few TY TS ( mostly A model ) , I brought 2 back to life and have look around for parts for 4 or 5 years,
    so if you need something that you can't find localy, pm me and maybe I will be able to point you in the right direction.
    Guy
