"BitDefender 8 Free Edition is an on-demand virus scanner, which is best used in a system recovery or forensics role. If you are on an "always-on" Internet connection, we strongly advise you to consider using a more complex antivirus solution. "
I've owned two Fantics over the years (240,309). Bullet proof engine and transmission!
The few things I didn't like were, the lack of needle bearings on the swingarm pivot (bushings),
the weak kick start lever (pinch bolt, splines and pivot pin) and aluminum axles, swingarm pivot bolt on the 309.
The 1984 TY250. The engine case would crack at the swingarm pivot from hitting the skid plate. This was changed later with the extra boss in the casting and mount.
On my Scorpa..........swing arm pivot nut fell off (owners fault for not checking all bolts for tightness)and the coolant hose vulnerability to damage.
Other than that I've had very few problems with my bikes.
I just grouped 12 ECM'S from 1980 Chevettes and hooked them all together.
In a simpler question, what do I need to do to get all my old(family) tapes, and mini DV up to a Keepable standard?
Should I just buy a DVD recorder for the video system? Or upgrade the computer? Is DVD here to stay, and which recording format is best? + - i do not get it.
I would suggest a DVD recorder for simple transfer if you don't want to do any editing.
I use this to record TV shows Panasonic DMR-ES20 and it works well. A little bit of a learning curve. Lots of buttons.
For the mini DV you'll have to hook the camcorder to the recorder via firewire ( IEEE 1394 same thing) or composite cables.
DVD- is more compatable but most new players play everthing (ie: DVD - +, DVD RAM, JPEG Photos).
You can still buy a turntable!
DVD'S will be around just don't write on it with a magic marker, ink pen, crayon, paint brush, engraver or a sharpie, get a marker made for CD, DVD's (water based).
Here's a site with a player compatabilty list. >>>
Real Dumb Question
in Anything goes
Posted · Edited by Dabnabit
who the heck is url? I don't know any url
URL
