I use tube type IRC tyres on my ossa i have just put a new one on, my last one had a date mark 2006 i new it had been on a long time. I only noticed it not gripping as well this year in the dry (gone hard with age) ive had my moneys worth! if you want to reduce unsprung weight i would look at an alloy axle and shocks
Woodys advise is very good, but i have rebuilt my motor two or three times over the years. I bought the ossa clymer manual for the MAR and followed that (even tells you what gas mark for the oven to get the bearings out of the crank cases) clean the cases up first though cos the kitchen will smell bad!!!!! take your time and photos can help.
i bought a set of cheap pullers and modified the ends to get the sleeve off the end of the crank, works well but they are always tight.
we have just been away with our touring caravan, nose weight was about right and towed great but when the van pitches back and forth through bumps etc the cars suspension and tow ball get a lot more hammer than when i have my bike on the rack.
i also have rubber spring assisters on the rear car shocks.
OTF, i would say Peak classic trials venues are hard to compare with the pre 65 scottish sections plus Davy has ridden in the ssdt for years as well as the pre 65, I hope he has kept his feet on the pegs today too. If he can win his dad will be very proud!
There could be a number of reasons for the lack of go, If i retard my ignition my ossa goes as flat as a pancake, mine is a gripper but i think top dead centre is the same (2.3mm before TDC from memory)
could be airfilter not able to breath, wrong size sprockets, chain too tight, carb worn. may even have a thick head gasket, mine is 1mm i think you can buy up to 4mm.
brakes, new shoes and shims should make them work you wont be locking the front end up though.
forks, old saggy springs? too heavy oil? 7 to 10 wt. could the fork leg clamp at the spindle be set wrong. Bad crome?
All the above except forks are cheep easy and easy to fix.
Ive had falcons (steel body) on my ossa gripper for years, pos 14 years. They have had some stick over the years.
I can rebuild them myself when needed. The only mod i have done is drilled another hole in the rebound side of the damper piston and now run 7.5 wt oil and 65psi air.
The people that have ridden my bike say it is about the closest to a mono they have tried.
look at fantic page on here under what fantic. i had a k roo like this in 1991 (blue & yellow) mine was a 250cc good powerfull bike.
The only problem i had was when it got very hot it spat coolant out of the water expansion tank and i had to top it up. Radiater was in the frame under the fuel tank. steve.
John's BSA Exhaust is a work of art in itself , after exiting the cylinder it turns left and goes right around the cylinder and enters the back of the silencer above (i believe ) where the tailpipe exits. Johns bikes are always beautifully turned out and are ridden hard , In pre 70 events around the country.
Does John still ride his triumph twin? I have always admired the way he rode it, the sound always made me smile
I had a couple of yam ty monos the last one was in 1988 white frame one, i improved the front brake with a cable that the outer went right down to the brake plate. then i bought a yz125 brake plate with the arm on the outside, that was a big improvement.
Then i bought a new wheel with a disc brake thinking it was the latest thing and just had to be the best.It was rubbish! No power or feel, the yz125 plate was the best.
Two friends of mine had them, one still has, but neither had discs fitted although as previously said they were an option back in the late 60's but to the best of my knowledge at that time, and i was competing way back then too, i never saw one in our area but they were a factory available option when you ordered your kit.
Looks like i may have to amend the clubs rules again i did think think about this particular Cheetah option when i wrote the rules but as i had never actually seen one competing since the late 60's i didnt think there were any left.
Just goes to prove theres always something going to bite your bum when you least expect it. You wait somebody will turn up on a monoshock OSSA next
Monoshock Ossa,I could unbolt one of the shocks on the gripper for next Sundays trial.
OK OK Steve and Dave perhaps i was being a bit OTT on those two. Kill switch was for safety reasons having been traped once under my bike with my arm stuck between the rear tyre and the rear shock with the bike reving it's nuts off in gear and the only way i could stop the engine was to rip the plug cap off. That made me hair stand on end and i've still got the scars on my arm to prove it.
I'll mark the kill switch as advisory and delete the chain guard rule.
Thanks again for the input logical and well considered.
Paul, i will try to sort out a kill switch for my bike. I think for the clubs saftey angle if the rule is there the club is covered. thanks Steve.
Im puzzled to find a problem with what Paul has done here, he has put a new class in so whatever type of classic bike you come with you can ride it in a class to suite your bike.
Peak classic trials are always fun to ride, fellow riders are a good bunch too. Some have modified bikes some dont, its there choice what they do to there bike. now there is a class for everyone.
looking at the rules my only problem is i have never had a engine kill button on my Ossa and i have ridden it for 22 years, (never needed it) anyone know how to fit one?
Rhayader Classic Experts Tv Coverage.
in Classic Trials
That was great! i could not understand a word but that did not matter. looked a slippy trial. Thanks for posting on here.
Steve.
