91 -
I have always have used this http://www.splatshop.co.uk/Parts-Finder/Sherco/2009/290 to buy parts for my bike. Splatshop stock mostly everything for a 2009 Sherco, they post items fast and without fail arrived within two-three days (in my case). Rear Fender link :http://www.splatshop.co.uk/sherco-08-trials-rear-mudguard-white.html
Drills For Beginner On Non Trials Bike
lewis cosgrove replied to dandabs's topic in Trials Training And Technique
Try balancing with the bike off as you don't have the centrifugal force from the engine aiding you. -
http://www.splatshop.co.uk/putoline-light-gear-oil-1ltr.html I have tried ATF Dextron III and 10w40 but i find the above to be the best of both worlds.
I done a quick search on Google and can't find any info ? Where did you get this picture?
If it is in good condition £2000 is the right price i would say... Also its the best looking Sherco, in my opinion
The front does look a little fast and like its riding low if you know what i mean. Check that the front and rear go up and down the same amount when pushing the middle of the bike. You can adjust the forks dampening and rebound using the screw adjusters on top. Stock Settings Right leg: "Recommended: unscrew entirely and screw two clicks" Left leg: "Recommended: red cap flush." Change the fork oil that will improve the feel. Great riding btw
Bleed the clutch, could be air in the system?
Loads of info here: http://trialstrainingcenter.com/how-to-ride-motorcycle-trials/introduction-to-tutorials/
Splatshop's clutch tool was listed 2001 - 2005 I got a bit worried so email them and they confirmed that it would in fact fit 1999 - 2014. So yeh, i would go ahead with the £18 one.
There is no huge difference in motors from 1999 - 2010, only minor tweaks. At the end of the day all the tool has to do is slot into the clutch basket and the center hub which are definitely the same. Have a look at these links, look at the range of years these parts fit. http://www.splatshop.co.uk/sherco-clutch-basket.html http://www.splatshop.co.uk/sherco-clutch-hub.html http://www.splatshop.co.uk/sherco-clutch-friction-plate.html http://www.splatshop.co.uk/sherco-metal-clutch-disc.html And to answer your question about if there could be damage done. If the spring has snapped make sure to find the broken parts and check that the teeth on all the gears are OK.
This is the cheapest clutch holding tool for a sherco i can find, no need to pay £70! http://www.ebay.co.uk/itm/111137408196?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Sounds like the kickstart return spring is broken : http://www.splatshop.co.uk/sherco-kick-starting-spring.html Here's a guide on how to change the spring. http://www.splatshop.co.uk/kickstart-return-spring-fitting-guide.html
You really aren't going to feel the difference between 50:1 to 80:1. There is no universal ratio for every bike, it depends on how you ride. Are you mostly just putting about? 70:1 / 80:1 will be fine. Riding fast in high gears a lot? The factory recommended 50:1 will give you peace of mind. Anywhere from 50:1 to 80:1 will do for any circumstance though. Just pick what you think is most suited. Here's a link that goes into detail. http://www.trialscentral.com/forums/topic/48320-oil-mixture/
"it goes on and on" .....................................
