I use the Turnigy 3s -2200 mah batteries in my RC Helicopters.
They are very good batteries...but for charging you need a proper lipo charger with built in balancer or you can use an external "blinky" (balancer).
Either way you can only charge 1 pack at a time, per charger.
While you could try and trick it into charging the combined packs together, over time you would see a serious degradation as the cells would become too far out of balance in each pack.
Well. there you are Mr ahh_me2. I bet you never thought your first post on the forum would provoke a discussion on the physical properties and chemical composition of WD40.
Now you are on a trials bike......just slacken the chain off until the top of the rubber tensioner chain slipper block has a gap between it and the underside of the rear swing arm that you can fit your first/index finger tip in and that's it.......the chain is too tight in the picture.
Yeah, I was dealing with fluids today so didn't get much chance to look at the chain.
I know I'll have some questions about it though...
I do know it needs some lube, not sure yet what should be used.
Just bought a 2001 Rev3 250 and wanted to check the fluids, after removing the plastic cover on the left side of the frame/tank, I saw the "rad cap" but it seems there is
a plastic/metal block preventing it from un-threading upward, what am I missing? other than a few brain cells lol
Greying beard, rode lots of dirt bikes and some motocross over the years, not a pro by any means, just riding for fun.
Always wanted to ride trials...
Been reading this forum for a while trying to gain some knowledge about purchasing a used trials bike.
Being in Canada, trials bikes are few and far between, and I didn't want to spend too much to get into trials at this point.
I finally found an older Beta Rev3 250, 2001 for a low enough price, it was probably more used for trail riding before though
but seems in reasonable condition otherwise.
While I have numerous questions...lol... I will reserve those for future posts and use this as an introduction only.
And YES!!! I will post the mandatory trial porn pics of my latest acquisition!
Oh , and did I mention I'm on 3 acres of land and I've been doing a lot of logging lately....hmmmm, what to do with the logs....tough one! cut em' up and burn em?
Thanks for having me here, I have lots to learn so will go back to reading with my mouth shut!
Battery upgrade
in OSET Electric Trials Bikes
Now if you were to use a few of these batteries in parallel
https://hobbyking.com/en_us/zippy-compact-4000mah-10s-25c-lipo-pack-xt90.html
Specs:
Capacity: 4000mAh
Voltage: 10S1P / 10 Cell / 37v
Discharge: 25C Constant / 50C Burst
This would give your 36 ish volts, at whatever ampacity(wattage) you need.
You would still need an appropriate balancing charger.
