Snipesleft
    6
  1. did you figure it out? I'm having similar issue with my rear brake on 2017 txt 250. lmk how you did it please. thanks!
  2. I replaced the inside of master cylinder with a new rebuild kit. came with a new spring, I don't know what it's called but the long metal cylinder thing that pushes in and out and finally the circlip, then the rubber boot. everything in there works fine. so when you say better off with clear tube over fender, is it just a long hose connected to the bleeder screw?
  3. I was riding and clutch was getting less pressure at lever until no pressure at all. I managed to ride back to truck. i found a burn mark on line by the exhaust pipe and lower was wet on line towards clutch cover. i opened master cylinder ( mineral oil) and was empty. I just sold my KTM 300 so have changed out my clutch line before but on the Gas Gas do I just unscrew the line from clutch cover and master up top and replace then use syringe to force mineral oil from bottom up? mahalo! riding on Oahu🤙🏾
  4. I was riding and clutch was getting less pressure at lever until no pressure at all. I managed to ride back to truck. i found a burn mark on line by the exhaust pipe and lower was wet on line towards clutch cover. i opened master cylinder ( mineral oil) and was empty. I just sold my KTM 300 so have changed out my clutch line before but on the Gas Gas do I just unscrew the line from clutch cover and master up top and replace then use syringe to force mineral oil from bottom up? mahalo! riding on Oahu🤙🏾
  5. Newbie here with a 2017 Gas Gas TXT 250. Clutch line leaked out on my ride today 😩 reservoir dry. had to ride back few miles with no clutch. just ordered a new line but how do I change it out? any help please Mahalo in advance!!!🤙
