13 -
What grease should I use on the rear linkage bearings? 2004 txt pro will waterproof marine grease be ok, or lithium waterproof? Thanks, Mat
Hi, Thats perfect, thanks very much for taking time to write up all the info for me, I will wire it up then check everything before kiching it over to see if I get a spark, I should be able to get it all going now, will let you know! Mat
Hi, Thanks for your help, I can
I have a TXT Pro 2004 that I am rebuilding, just need to get the electrics sorted out but I am not 100% sure If I have everything and how it is wired and where eg the CDI unit fixes to the frame, can anyone help by posting a photo of what is under the tank? I have found some wiring diagrams on the net but dont know what is correct, and the parts list / diagram from GasGas does not show where bits go, I can post a photo or list what I have if that helps! Thanks
will EP80W/80 Gear oil be ok 500ml ? found this out as it was in another post about a section
As title really! How much gearbox oil and what type for a 1994 K Roo 249? Thanks, Mat
Thats what I would of done, but it does not have a bleed nipple, the pipe just goes in to the engine casing, the slave cylinder and I guess bleed nipple is hidden away! It now works well from pumping it and cable tie the lever in all night!
This is what www.sparkplugs.co.uk reccomend, both Champion plugs I think Manufacturer FANTIC MOTOR Model K-Roo 249 1Cyl (2-stroke) Engine Size 250 Production Year Not Specified Power Output (KW) Not Specified Standard Gap 0.5mm Part Number N6YCC Manufacturer FANTIC MOTOR Model K-Roo 1Cyl (2-stroke) Engine Size 212 Production Year Not Specified Power Output (KW) Not Specified Standard Gap 0.5mm Part Number C6YCC And mine has a Bosh Super+ FR6D+ Plug fitted! so what plug should I get? stick with whats in it, or get the champion reccomend by sparkplugs.co.uk, or get a NGK equivalent BP8ES that sparkplugs.co.uk comes up with if you use the cross ref! Mat
My 94 K Roo is a 249cc, I can tell you what plug is fitted to mine (will look later), but it might not correct so I would also like to know the correct plug! Mat
Thanks for your help greeves, I will give it a try, Mat
How do you bleed the clutch on a 94' k roo 250, there is no bleed nipple (unless its inside the engine casing) the pipe just goes in to the casing on the opposite side to the clutch! can you just bleed it from the lever? or do you have to bleed it from the slave cylinder? I have got as much of the air out as I can from just pumping the lever but it still has air in the system and the clutch wont disengage fully, is there a trick to it? anyone know where to get a workshop manual? Thanks
Hi, I will soon be getting an MOT on my Fantic, I already have the V5 doc with reg number etc. can someone confirm that this is all correct; No lights required, day time use only MOT only, (any reflectors required?) No Speedo required. (should it be present, but just not checked?) There's no requirement for a number plate (but I will have one fitted) Tyres should be E marked Continuous tone horn required with own battery Should the exhaust be marked road legal? Thanks, Mat
Hi, I have just bought a 1994 Fantic k roo 250 as a project, it was a non runner but the engine now runs great! I
