September 22, 200620 yr any one have an alp? i have no manual and i have no spark. it might be the same system as a zero. i think all i need to know are the ohms specs on the coil etc. thanks jer
September 22, 200620 yr Hi Cannot help you with manual - but I did a fair bit of top end work on one of these motors which was fiited to the Imported Suzuki Djebel. This is basically a Suzuki DR200 - and this is probably a better route for you to find manual / parts etc - I do not think the Zero will help you. I recall I found a very good web site called Alpha Sports - which was excelent for part diagrams etc They specialise in snowmobiles and bikes etc and I think are based in Canada - do a search and you should find it.
September 22, 200620 yr Hey Powellriver315, have you tried contacting your local Beta dealer which is right in your back yard?? mark grey?
September 22, 200620 yr The two stroke Alp uses the Techno motor and Ducati ignition. Where is Ron, he knows!
September 26, 200620 yr Author am i correct in thinking this thing is a t34 from the late 80's? local guys don't seem to have info on this vintage. it would be great to get some info on the ignition if anybody still has some. who is ron?
