October 1, 200620 yr Hi, I'm currently trying to tidy my fantic 240 pro and after having the frame powder coated would like to re-paint the engine. What would be the best way to go about this? Should I have it shot blasted then give it a coat of PJ1 or similar? Any advice would be appreciated. Ross Also, how much fork oil does each leg take? Cheers Edited October 1, 200620 yr by mcerem
October 1, 200620 yr I don't know how much your going to spend on this, but I would find some LPS cold galvinizing spray paint, sand blast the engine and us the LPS as a primer. It's very strong, not real smooth thats why I would us it as a primer. I used it on a header pipe and it lasted a long time.
October 1, 200620 yr I have disasembled the engine, then build it together whitout the crankshaft etc. All the holes where closed. Then the cases and barrel where sandblasted and after that the engine is powdercoated. Each fork leg needs at least 295 cc.
October 1, 200620 yr Author Thanks for that. Do you think I could get a decent finish from just spraying it by hand with cans of engine paint once its been shot blasted?
October 2, 200620 yr Yes it is possible but you have to use solvent resistent paint like VHT Spray's for example https://www.usautomotive.co.uk/store/script...p?idCategory=92
October 7, 200620 yr You can get a very good finish with PJ1 satin black engine paint, prepare the castings well and cure the paint in the oven once it has dried. Use 230cc of fork oil per leg, handbook says 10w but I prefer 5w.
October 9, 200620 yr Author Thats great, thanks for the info What sort of temp should I cure the paint at and how long should i leave it to dry for before curing? Edited October 9, 200620 yr by mcerem
October 10, 200620 yr I leave it until it is touch dry (2 coats) and then cook it at about 150 Edited October 10, 200620 yr by Grib
