Twin Shock Forks
Any one have any comments on what would be the best forks to retrofit and still be pre 1980?
Yes, I wasn't sure what he meant either.
Is it
1) the best forks from post 1980 from a manufacturer that also made forks pre 1980 such as say Marzzochis of a 240/300 Fantic which look exactly the same as the Marzzochis fitted to say a late 70s SWM but probably work better.
or
2) the best modern forks that you could get away with because they look similar in appearance to a set of pre 80 forks.
Edited by Woody
