arun1664 Posted April 5, 2007 Share Posted April 5, 2007 Does anybody know if you can use a sherco 290 front wheel in a Beta rev 3 ? Thanks Quote Link to comment Share on other sites More sharing options...
copemech Posted April 6, 2007 Share Posted April 6, 2007 I think the spacer is different, PM "rlracer" as he will know for sure! Quote Link to comment Share on other sites More sharing options...
rlracer Posted April 8, 2007 Share Posted April 8, 2007 Yes you can. I use the wheel I have as a spare to practice with. The spacers are just a little differant, don't know the spacer size off hand. Quote Link to comment Share on other sites More sharing options...
raga-rep Posted April 21, 2007 Share Posted April 21, 2007 Does anybody know if you can use a sherco 290 front wheel in a Beta rev 3 ?Thanks yes you can they fit everything but a mont,just the spacing is different. hubs are the same and so are the discs, ive just brought two brand new wheels for my scorpa only problem is they leek like a siv on the tubeless back wheel..fitted a brand new irc and the thing leeks out of every spoke including the valve..ive sealed every thing with bathroom sealant and that dont work either..i have put a tube in it now got fed up trying to seal the rim..does anyone know how to fix this problem??? Quote Link to comment Share on other sites More sharing options...
copemech Posted April 22, 2007 Share Posted April 22, 2007 Yes! Quote Link to comment Share on other sites More sharing options...
raga-rep Posted April 22, 2007 Share Posted April 22, 2007 Yes!yes!!!god damn it whats the secret???thankyou verymuch Quote Link to comment Share on other sites More sharing options...
copemech Posted April 23, 2007 Share Posted April 23, 2007 (edited) Be sure you have not poked holes in the rim band with the tire irons! Inspect it closely! Clean it all up good as new and follow instructions! linky Use soapy water and fingers only to seat the band fully(reallllllly soapy)! And you may want to chunk that "collar" thing! When installing tire, DO NOT TOUCH the band, or you may damage or unseat it! It must be perfect! Good friggin luck! Practice makes perfect! Edited April 23, 2007 by copemech Quote Link to comment Share on other sites More sharing options...
