April 19, 200719 yr Right then all you 4rt riders which throttle body would you recommend to use? the 2 stage switch type (soft/mental) or the full programable one you can alter yourself or buy programmes for? if the programable one is better whick map would you recommend? Doing this post for Dad as hes keen on getting one of the units but has no real clue which is the better. Any comments much appreciated Thanks Just Edited April 19, 200719 yr by Betarev3
April 19, 200719 yr no difference,both fully programmable. 2 map you can just switch between 2 maps ,as it says . 2 stage does not come with 250 maps though they need to be installed.
April 21, 200719 yr i can do that Munch, you have my attention. Now tell me about the magic box with lights. No not the telly.
April 25, 200719 yr Does anybody have tried to hack the bodies, because the default body has two maps, one for road registration purpose and one for riding competition. The second one is enabled when disabling the lights, or cutting the white/green thread in the main light connector. The information i have is that a guy who had bought a HRC 260 kit (cylinder, piston, camshaft and switch) had to send his original body to the factory in spain where they modified the two maps for use with the 260 cylinder and switch on the handlebar. On the internet is a lot of information find how to modify ECU's for Honda autocars, but not for Cota's. Edited April 25, 200719 yr by fantic303
April 25, 200719 yr no difference,both fully programmable. 2 map you can just switch between 2 maps ,as it says .2 stage does not come with 250 maps though they need to be installed. if you have the cable and a laptop i will e-mail you maps i have 4 maps by the ferret flasher cheers
April 26, 200719 yr no difference,both fully programmable. 2 map you can just switch between 2 maps ,as it says .2 stage does not come with 250 maps though they need to be installed. if you have the cable and a laptop i will e-mail you maps i have 4 maps by the ferret flasher cheers Hello, i have a lot Ingnition Maps (mitani, Otar amos). If you need it send me your email to jmacheda@gmail.com
April 26, 200719 yr Hello, i have a lot Ignition Maps (mitani, Otar , personal). If you need it send me your email to jmacheda@gmail.com
