73anth Posted June 7, 2007 Share Posted June 7, 2007 just removed all the lights and horn ect, the kill switch was part of the light switch assembly. i want to fit a switch, where do the wires go??? Quote Link to comment Share on other sites More sharing options...
toofasttim Posted June 7, 2007 Share Posted June 7, 2007 Can you tell us which model? It will help. If it's a pro, can you wait until I get home? Quote Link to comment Share on other sites More sharing options...
73anth Posted June 7, 2007 Author Share Posted June 7, 2007 LOL..its a 2000 txt Quote Link to comment Share on other sites More sharing options...
toofasttim Posted June 7, 2007 Share Posted June 7, 2007 Oh, OK sorry I can't help. Quote Link to comment Share on other sites More sharing options...
peterb Posted June 9, 2007 Share Posted June 9, 2007 Hi Anth, Have you been practicing at Charltons again? The 2000 TXT has Kokusan ignition fitted. There is a low tension wire (not the HT lead) exiting the ign coil under the petrol tank, usually black. Trace this wire as there should be a spare parallel connection for the original kill switch somewhere. The kill switch will be a single or dual wire switch. If a single wire switch, connect this wire to the spare parallel connection on the low tension wire coming from the coil, Do not disconnect the low tension wire from its present circuit. The kill switch is there to short out this wire to ground. If a dual wire kill switch, connect the other wire from the switch to ground. A picture would be much easier. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
73anth Posted June 13, 2007 Author Share Posted June 13, 2007 Hi Anth,Have you been practicing at Charltons again? The 2000 TXT has Kokusan ignition fitted. There is a low tension wire (not the HT lead) exiting the ign coil under the petrol tank, usually black. Trace this wire as there should be a spare parallel connection for the original kill switch somewhere. The kill switch will be a single or dual wire switch. If a single wire switch, connect this wire to the spare parallel connection on the low tension wire coming from the coil, Do not disconnect the low tension wire from its present circuit. The kill switch is there to short out this wire to ground. If a dual wire kill switch, connect the other wire from the switch to ground. A picture would be much easier. Bye, PeterB. hi PeterB, yea just getting back to the charltons after a 5 week break, due to drowning my bike there, & training for a coast 2 coast bike ride. if i remember rightly, there is a single black wire coming from the coil area. so if i get a twin wire kill switch, i solder one too the black, & the other to the frame? cheers anth Quote Link to comment Share on other sites More sharing options...
peterb Posted June 15, 2007 Share Posted June 15, 2007 Hi Anth, Yes, just like you say. But leave the black wire connected to it's original connection. You will just be connecting the kill switch into the circuit as a parallel connection leading to ground. (The kill switch will ground out the black wire going to the HT coil). Are you still able to practice at Carlton Bank? Had good sections there. Good luck in the coast to coast. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
73anth Posted June 15, 2007 Author Share Posted June 15, 2007 Hi Anth,Yes, just like you say. But leave the black wire connected to it's original connection. You will just be connecting the kill switch into the circuit as a parallel connection leading to ground. (The kill switch will ground out the black wire going to the HT coil). Are you still able to practice at Carlton Bank? Had good sections there. Good luck in the coast to coast. Bye, PeterB. im not to sure if you can practice at carlton, but trials are still held there. thanks for the advise. regards anth Quote Link to comment Share on other sites More sharing options...
