the addict Posted August 10, 2007 Share Posted August 10, 2007 (edited) Has anyone used these before? look pretty good and better than Heli-coil by the look of them, usually strip a thread at least once a year and its a bloody pain taking something to get it fixed so if a thumbs up I might invest in a kit. Very usefull for the heavier rider who does a big jump and folds up their cam adjusters and shears the adjuster bolts clean off at the same time Time Serts Edited August 10, 2007 by The Addict Quote Link to comment Share on other sites More sharing options...
mort Posted August 10, 2007 Share Posted August 10, 2007 i can highly recomend them.much stronger than helicoils and very simple to use. Quote Link to comment Share on other sites More sharing options...
copemech Posted August 11, 2007 Share Posted August 11, 2007 I have them/ use them, seem to work very well in many situations. Quote Link to comment Share on other sites More sharing options...
the addict Posted August 11, 2007 Author Share Posted August 11, 2007 Thanks guys I'll give them a go Quote Link to comment Share on other sites More sharing options...
paulthistle Posted August 12, 2007 Share Posted August 12, 2007 I have both and use both. I prefer Helicoils. The Time Sert is easily uncrewed when removing a fastener. The Helicoil will stay in place. Also the design of the helicoil allows it to "Press into" the parent metal reducing the chance of stripping, and making it much stronger than the original threads. The Time sert pulls against the threads you have cut, just as the original did. Both have their place and can be used successfully. Quote Link to comment Share on other sites More sharing options...
