edgas250 Posted August 13, 2007 Share Posted August 13, 2007 My bike has developed a noisy fan, not sure what it is, i have checked there isnt anything in the way of it and there isnt, anyone any ideas? thanks Quote Link to comment Share on other sites More sharing options...
uhoh7 Posted August 14, 2007 Share Posted August 14, 2007 when it starts to squeal stop it with your finger (don't forget to wear a glove). this is reputed to often "fix" the squeal. i ended up getting a new fan. BTW sure you know but keep that washer away from the fan. Quote Link to comment Share on other sites More sharing options...
edgas250 Posted August 14, 2007 Author Share Posted August 14, 2007 the sort of noises is like when you used to put a card or coke can in you back wheel of your push bike? but obviously not as loud, Thanks Quote Link to comment Share on other sites More sharing options...
spinner Posted August 14, 2007 Share Posted August 14, 2007 What year Pro is it? If it is one of the newer ones with the rubber cover on the back of the fan, Pull the cover back a put a couple of drops of spray lube on the end of the fan shaft. Won't hurt anything, It stopped mine from squealing Quote Link to comment Share on other sites More sharing options...
edgas250 Posted August 14, 2007 Author Share Posted August 14, 2007 its an 05, think its a plastic fan cowling Quote Link to comment Share on other sites More sharing options...
peterb Posted August 16, 2007 Share Posted August 16, 2007 You might have a stray electrical wire hanging in the way of the fan, or the fan blades catching on the shroud - check for marks on the blade edges, or if the brass bushes inside the fan are worn, the motor could squeal. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
