Bulto 199 Steering Taper Bearings( Result)
hewson
Hi all, just received some taper roller bearings today which are the right size( bore25mm dia 45mm width thickness 12mm)got these off pyramid parts adverting in classic dirt bike . (WWW.PYRAMID-PARTS.COM) TEL 01387 269985 (
Hi Dabster,wots the other 50 mods then,was going to contact you ,asked a question recently about 340 mods, big john said your the man for the job.Im part way through a bit of a rebuild , im also after a piston, i need to rebore it, my current piston says t2+ on it ,is that second oversize ?.Any info would be gratefull .CHEERS
