September 19, 200719 yr hi all,just got a 07 repsol 4rt,love the bike but the fan seems to be cutting in alot more than my rev 3 did?? do there all do this?after a few minutes from starting it up the fan cuts in,is there anyway to keep the engine cooler?
September 19, 200719 yr Have to say mine does exactly the same.... Yeah my mont was the same when i first got it, they all do it. Gotta keep the beasts tamed. Dont worry about it, at least you know the fans working.
September 19, 200719 yr hi all,just got a 07 repsol 4rt,love the bike but the fan seems to be cutting in alot more than my rev 3 did?? do there all do this?after a few minutes from starting it up the fan cuts in,is there anyway to keep the engine cooler? Common trait of the four-stroke motor, they run way much hotter than a two-stroke. Fan cutting in often is OK, they tend to settle down after a bit of use, but they will tend to cut in more often than a 2T motor. Situation normal as they say. Big John
September 20, 200719 yr hi all,just got a 07 repsol 4rt,love the bike but the fan seems to be cutting in alot more than my rev 3 did?? do there all do this?after a few minutes from starting it up the fan cuts in,is there anyway to keep the engine cooler? Take your glove off and feel how hot the fuel tank gets It'll take your mind off the fan cutting in
