joe87 Posted October 5, 2007 Share Posted October 5, 2007 My rear brake lever suddenly started rubbing on the chain. There was left to right movement on the lever so I changed the bearing and the bush/nut. I refitted the lever but it still had play on it and touched the chain. I was wondering if I was missing a shim on the bush? Any suggestions??? Quote Link to comment Share on other sites More sharing options...
paul w Posted October 5, 2007 Share Posted October 5, 2007 (edited) is the chain tensioner bent? or look at the footrest bracket they bend for fun! Edited October 5, 2007 by paul w Quote Link to comment Share on other sites More sharing options...
gsade Posted October 6, 2007 Share Posted October 6, 2007 This happened to mine the other week, Didn't know I'd done it but had dinged it on a rock - when I thought back I could remember the culprit! Took it off, popped in the vice & warmed it up a bit then carefully bent it out by a couple of mm - there's very little clearance between chain & pedal at best of times so even an almost inperceptible bend (couldn't visibly see any on mine) will cause problems. Hope this helps Ade Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted October 6, 2007 Share Posted October 6, 2007 On every one of these i have had i have had this problem and if its just rubbing slightly i leave it. I know you could heat it to straighten it but even at that they are easy snapped. Quote Link to comment Share on other sites More sharing options...
joe87 Posted October 7, 2007 Author Share Posted October 7, 2007 Thanks for your help lads!!! Quote Link to comment Share on other sites More sharing options...
smalley250 Posted October 7, 2007 Share Posted October 7, 2007 Its one of two things with beta the rear brake and the silencer and well the carb. I have a gasser and it rides well but is made like a pram from india. Hope the 08 is ok as i aspect me gasser to last not to long. Quote Link to comment Share on other sites More sharing options...
