coxy Posted October 28, 2007 Share Posted October 28, 2007 hi could anyone help me with bleeding my rear brake as im finding it a pain in the a***, could some1 tell me the best way for it to be bled because i cant seem to get all the air out of the system and i have no back brake! thanks coxy! Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted October 28, 2007 Share Posted October 28, 2007 try with bleed screw tight, half a dozen pumps hold down pedal open bleed nipple tighten again.repeat few times job down Quote Link to comment Share on other sites More sharing options...
lepky1972 Posted October 28, 2007 Share Posted October 28, 2007 (edited) lift the back wheel higher than the fluid cup so the caliper is up high this helps to force any air to the top quicker or you can syringe the the fluid in from the bleed nipple biggest syringe you can get with a bit of pipe tight to grip the bleed nipple this also works for bleeding the clutch ican send you one if you cant get one Edited October 28, 2007 by lepky1972 Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted October 28, 2007 Share Posted October 28, 2007 Well worth buying if it helps sort the problem. Click here Quote Link to comment Share on other sites More sharing options...
postmanpat Posted October 29, 2007 Share Posted October 29, 2007 Hi,just had the same problem on a '99 gasser,and an'03 mont........go to a vets,get a 60ml syringe (about Quote Link to comment Share on other sites More sharing options...
