Rev 3 Reed Spacer Block
Hello all,
So I've seen a few posts regarding removing the reed spacer, doing so certainly does make it easier to get the carb in and out, but what is the consensus on effects on performance?
I remember seeing a post or two that claimed that it helped performance but I've also heard that having the spacer in place boosts torque? I am fitting some vforce reeds and wondering if I should go with or without spacer.
Thanks in advance,
Colorado dirt rider
2005 Rev-3 270
Edited by CODirtRider
Sorry I cant help you dirtrider....but i'll be following this post with interest since Ive been wondering the same thing myslef.
You'll probably get some more replies from this side of the pond when everyone gets out of bed....or back from work.
no, a spacer lengthens the inlet tract, therefore will load up the rear booster port ore efficiently, peakyer throttle response and more torque throughout the rev range
ive removed the reed spacer on my bike and to be honest there was no real noticable difference in performance,if something a little sharper off the bottom and thats comparing it to my brothers bike which is the same as mine but with the spacer on and his is an 04 and mine is an 06 so it could be the 06 is sharper than an 04 as standard
thanks guys, put the vforce in w/o the spacer, going to ride tomorrow and see how it feels :rolleyes:
