March 3, 200818 yr Hi there - I'm looking for a Transit Connect to replace my Berlingo. Does anyone know if the SWB version would take two bikes, if not what about the LWB? Cheers
March 3, 200818 yr swb hi roof is the tool you want i have that and a trafic the trannie is just as high as the trafic and will take two bikes
March 4, 200818 yr swb low roof connect will fit two bikes in no problem. Also if you can go for the tdci version (90hp). Edited March 4, 200818 yr by der italian trials
March 4, 200818 yr As said above the swb does take 2 bikes easy on the diag, also loads of room to get your kit in, if i had a choice at getting one, ( mine is a works van) i would go for the one witht the side door,
March 15, 200818 yr Author many thanks for the replies and tips, this is good news. Just need to find a nice clean used example Cheers
February 17, 201115 yr Hi everyone, I'm looking for something that will fit in my garage, i've tried a Hi top connect but it's just a tiny bit too tall to fit through the garage door - the short wheel base Connect will fit just fine As you can see [from pulling up this old thread] i've done a search, but i've read a 100 different answers saying that you can and can not fit two bikes [250 scorpa/270 Beta in my case] in a standrad low roof ford connect. So can someone please settle it once and for all and post a picture up of a SWB Connect with two bikes fitted in the back. Cheers.
February 21, 201115 yr So can someone please settle it once and for all and post a picture up of a SWB Connect with two bikes fitted in the back. Cheers. Anyone??
May 28, 201115 yr I've had both high and low roof versions, 2 bikes will fit in both, the vans are the same width which is the limiting factor, but the high roof makes it easier to do. Having owned many vans over the years I can comfortably rate the Connects as the worst I have ever had the
