Ty250 Disc Conversion
pat64
hello folks
iam thinking about converting my crap front drum brake to a disc.it is my understanding
that the forks and disc from a fantic will fit,can anyone tell me what model fantic i need to get the parts from.
sorry if this has been posted before.
cheers Pat.....
Not sure you'll get one to go straight in. I'm not familiar with all of the Fantic model's forks but most if not all up to the upside down fork models are 35mm. The Section model's may be larger than 35mm, not sure.
Not sure which Yam you mean but the mono Yam forks where they fit in the yokes are 36/37mm so 35mm forks won't clamp up. The twinshock Yam is 34mm so yokes are too small.
If it is a Yam mono you should be able to get a complete front end from a Pinky which will go straight in. Probably a better brake on that as well compared to the earlier Fantics/Betas etc.
GasGas front wheel and 4 piston AJP caliper and master cylinder and hose.
All slip on, no modifying the original forks.
Way better than the older conversions.
Search on this site, I posted info and pics in the past. I can email you the dwg of the bracket with all the dimensions.
k
