05 Txt Pro Water Pump Impeller
motorrad
Drained the coolent the other day. and noticed that if I was to hold the impeller, and push the motor over, the impeller would spin on the shaft. it did have some resistance, but not as much as I would have imagined. (I figured it would have been fixed myself).... Is this normal?
Edited by Motorrad
The impellor is threaded onto the shaft, it will unthread if spun the correct way and strip the threads out if forced the other way. If the threads are stripped out, it is a good idea to change the shaft and seal as a set (the shaft gets grooved).
Spencer
