September 22, 200818 yr Hi,whilst on my o4 290 yesterday,the bike suddenly boiled over.I had a quick look at the fan which wasnt running, but it started up when i reved the engine,but as the revs dropped to tick-over,the fan stopped.This continued for a few minutes,then the fan stayed on irrespective of the revs then went off when engine had cooled as normal, and i had no further problems.The bike was running as normal. Is this a sign of something about to go wrong?,any help woud be much appreciated Edited September 22, 200818 yr by dabomb
September 22, 200818 yr Author Did it turn off afterwords? Yes,sorry,the fan went back to working normally and was ok the rest of the day
September 22, 200818 yr Author You may have had a foreign object stuck in the blades.Wayne There was defintely nothing there,i could spin it freely.That is the first thing i looked for. Edited September 22, 200818 yr by dabomb
September 23, 200818 yr What you describe sounds as though the rectifier may be going. I would ck the connections first.
September 23, 200818 yr Author What you describe sounds as though the rectifier may be going. I would ck the connections first. Thanks copmech.But there doesnt seem to be a rectifier according to the parts book.There is a regulator or a diode(which in spanish tranlates as rectificador).Could this be it?? Thanks
