Honda Tlr Brake Shoes
stump magnet
ok have tried new original shoes and ebc shoes and brakes are still crap on my 200 are newfren grooved shoes any good? has the "I" cams everything else is as it should the back brake is pretty good to be honest as i have fitted a longer arm on the cam. the front is the larger reflex type which uses the larger 110mm brake. to have the shoes re=lined larger and machined back is over
Edited by stump magnet
hey,
idd only use honda brake cable there are the best
sure the hub is not used out?
i have stock honda brake and it works great
the 250's brake is better than a 200's but a 200's should work to
regards bob
cheers guys the reflex brake is the same diameter and uses the same shoes as the 250 where on earth can i get a new honda cable? david silver spares says there discontinued! who has em?
When I was younger I had a gollner 200 mono and a fantic 200 and never had a problem with my brakes, I can only put this down to regular maintainance I think the shoes that were used was ebc. This will sound like a bit of a ball ache but the day before a trial I would remove both wheels clean out the hubs and wire brush shoes reasemble and adjust up but this would give almost as good as a disks of the time. :D
