March 23, 200917 yr Hi all, first of all thank you to the people that gave advise on the 01 321 verses 06 300 decate. I bit the bullet and bought the 06 300. The wife will have to wait for the new kitchen a bit longer. The only switch left on the 'bars is the kill switch. Can any one tell me where to look for the wires that would have been connected to the rain/sun switch. And what colour they should be. Also I have seen some other posts that suggest that if apart that the setting is rainy can some one confirm. Thanks for your time.
March 24, 200917 yr Have a look under the tank... you will see the CDI box..... (black box) they will be a black wire and a orange wire.. Join together is soft setting, pulled apart high setting... you rellay have to screem the s##t out of the bike to notice any real diffeacne...
March 24, 200917 yr Have a look under the tank...you will see the CDI box..... (black box) they will be a black wire and a orange wire.. Join together is soft setting, pulled apart high setting... you rellay have to screem the s##t out of the bike to notice any real diffeacne... From what I understand, the curve differential starts at about 2500 RPM. If you want, ask your dealer for part #BT280634007 and the "mode switch" just plugs in to the black/orange wires. Jon
March 24, 200917 yr Join together is soft setting, pulled apart high setting... Ooops..!! I joined the connection on my sons 125 when I removed the switch last year. Maybe thats the reason the bike is a bit "lazy". -Jan
