May 3, 200917 yr I have just finished screwing together my 200. It's been going on for around 2 years! I've replaced various bits, powder coated the frame, new ring, small end etc but done nothing to the bottom half of the engine. The bike ran ok prior to the strip down. Now i have no spark. I've checked the plug cap and replaced it also the plug. The coil is not orginal and is rewired as it came off. I've removed paint to ensure a good earth. Not sure of the make but it has markings for a red, green and white spade turminal plus a black cable. I haven't removed the fly wheel as i don't have the right puller. Any ideas what or how to test next?
May 4, 200917 yr I assume its a minarelli motor? check black to red, should be about 400 ohms black to green should be about 45 ohms. Any where close will be ok to start it. If the stator is very old, it may break down when hot, but will restart when cold. then it needs rewinding....fleebay The insulation falls off the green more than the rest. Check this first If the green wire to gropund is open then the trigger is broke....bill pyes yer man Pullers are available from steve goode Edited May 4, 200917 yr by Lee Harris
May 4, 200917 yr if you get this far ok then the coil will either be round metal 8dabnsi9 or red/blue/black plastic wire it like this as appropriate
May 9, 200917 yr Author It turned out to be the screw in the flywheel/trigger. I just cleaned them and away she went This was after talking to Mike Hann.
May 10, 200917 yr Author The story contiues: although it would run fine it needed a gentle push to start. I decided to decrease the gap of the screw to the trigger. Of course i snapped the screw off I've locked the doors................for now. Edited June 16, 200917 yr by Whizzy
May 17, 200917 yr Author I've got the flywheel sorted out now but still no spark The black to red reads 380 ohms The black to green reads 43 ohms i assume this is ok. Should there be continuity between red to green? I have 423 ohms. Is there any connection with the lighting winding on stator? Is there any way to test the coil? it looks new ish. It's black plastic with four male spade terminals.
June 16, 200917 yr Author The saga continues, new flywheel fitted- no better. Although the resistances seem ok i decide to get the stator rewound. It arrived in the post yesterday and was duly fitted last night. Second prod on the kickstarter away she went Thirty seconds later whilst idling away she pops and bangs and stops The key on the flywheel had sheared Ah well i guess progress is being made. Watch this space for the next problem. Edited June 16, 200917 yr by Whizzy
June 16, 200917 yr Yer the 200 flywheel needs to be tight,do you have a torque wrench. Make sure you use a six sided socket,them flywheel nut's round easy.
June 16, 200917 yr Author Yer the 200 flywheel needs to be tight,do you have a torque wrench.Make sure you use a six sided socket,them flywheel nut's round easy. yep did all that as per the manual 5kg/m. Guess the key was just worn through all the on and off of the flywheel lately, it didn't protrude much above the shaft. I'll know more when the new one arrives.
June 16, 200917 yr Author I normaly lock mine up at 50 ft/lbs that comes out to about 6.9 Kg/m. cheers, i'll give it a bit more next time then.
June 18, 200917 yr Is that the thread on the shaft or the nut? Either! Seriously, the flywheel you said the flywheel had been replaced? The shaft taper and the flywheel taper need matching exactly. This was done in the plant and new / different flywheels or flywheels which have turned at high speed due to a woodruf key shearing are no longer matched to the shaft taper. go and get some valve lapping past, or grease and a handful of sand (only kidding) and lap the flywheel, without the key onto the shaft. i.e line it up approx and rotate back and forth 15 degrees with lapping paste in between. You will see the shaft take on a dull grey colour. If this is only 1mm or so wide, the flyheel will only sit on the shaft that much. Lapp away until the band is nice and wide. Then clean the paste from shaft and flywheel and screw it up nicely with a new woodruf key. Away you go....... Edited June 18, 200917 yr by Lee Harris
